MUSTA NOTSU RALLY
Teema algataja - Postitusi: 15
- Tsikkel: KTM 990 Adventure 2007
MUSTA NOTSU RALLY
Toimub unimotode kiirendus võistlus. Selle aastal veel klassidesse ei jaga masinaid kuna meid on veel Eestis natuke vähe. Osa saavad võtta kõik kes on endale unimoto ehitanud.
Päeva parim lahkub koos 500 euroga.
EHITAMA.
Ürituse lühikirjeldus
Ürituse algus - 6.augvust kell 12.00
Ürituse lõpp -7.august kell 12.00
Ürituse asukoht.- Võrumaa Mõniste vald Tiitsa küla
Ürituse korraldaja - Wildhogs
Lisa info 56200949
Re: MUSTA NOTSU RALLY
Natuke ka reeglitest mille järgi tegutseda.
The Rules:
1.You drive a 30,49 meter (100 feet) off the cuff. For a valid run, the driver has to be on the vehicle the whole time. Skids which are in front of the driving wheels have to touch the ground at the start. Who is the fastest out of all Runs in his/her class wins.
2.The range can only be on natural ground like gras or field, etc.. The race course can be straightened and compressed with agricultural machinery or mowed with a lawn mower. The driver has to finish the range on only one wheel!
3.The propulsion unit of the unicycle/unimoto has to be older than 5 years.
4.The propulsion unit can not be altered with power enhancement. Only one propulsion * unit can be built in.
5.The Unicycle / Unimoto can not be longer then 2.438 meters (8 feet) and not wider then 1.219meters (4feet).
6.Categories:
electric propulsion
less than 200 cm³
less than 400 cm³
less than 750 cm³
bigger than 750 cm³
Rocket- / Jet- / Pressure- propulsion: IMPORTANT! Rule Nr. 7 and after consultation with the Event Coordinator.
7.An emergency stop has to be mounted, to stop the unicycle if the driver / the unicycle / the unimoto falls.
The connection between the emergency stop switch and the driver's hand must be kept as short as possible, so that the switch gets triggered, when the driver releases the handlebar.
The connection to the hand itself must act tightening, or is connected with a carabiner or a similar object.
8.A brake system has to be installed. Helmet and protective clothing are an obligation.
9.During a race, nothing can touch the ground in front of the single built in wheel.
10.Nothing on the unicycle/unimoto can be built in, that can change during the race or change its position on the vehicle, to release the time measuring system at take off or the finish line earlier.
- Propulsion unit: It can be built e.g. out of three or eight motors, but it can not be used an extra second propulsion unit, (e.g. injector, spring, muscular strength). Injector, spring, muscular strength or others would be an own propulsion unit. Three injectors without extra propulsion units are possible, etc.
Important Note:
Every Unimotos / Unicycles can only be used once for each race! That means, if a race is held with 3 runs, the unicycle / unimoto can be used a maximum of 3 times. The number of drivers is irrelevant
