Nx650 tagaratta võll kinni. Abi?
h0lger
Teema algataja - Postitusi: 510
- Tsikkel: roheline
- Tänanud: 109 korda
- Tänatud: 30 korda
Domika tagaratta võll on nii kõvasti sisse mädanenud, et ei taha kuidagi välja tulla. Võtsin kiige küljest ära ja proovisin kuvaldaga veenda, aga kasutult.
On siin keegi, kes oleks nõus sellise probleemiga aitama? (Ilmselt oleks mingisugust pressi vaja)
Holger
5107209
h0lger
- Tsikkel: roheline
- Tänatud: 30 korda
Re: Nx650 tagaratta võll kinni. Abi?
Tallinnas.
Eile lasin sinna umbes pool purki WD40't vahele ja jätsin külili imbuma. Täna proovin korra ise veel.
jaan mmc
Võibolla tömbi otsaga automaatmeisliga võlli otstest meiseldades, hakkab pikapeale liikuma
Rattalaagrid see menetlus muidugi hävitab, halvemal juhul ka laagri pesad...
- Tänanud: 145 korda
- Tänatud: 381 korda
Tsitaat ühest foorumist, ise ei ole proovinud aga jutt selline:
We all have ones we like to use. WD-40, PB Blaster, Kroil, and at least a dozen other brands are out there. Some work better than others and especially for us guys turning a wrench in the rustbelt we need all the help we can get. I came across an article that was actually in a machinist's publication that did a study on these to find the best one. They took bolts with nuts on them, all of equal size and grade, and left them in a pail of water for some time until they got good and rusty. Then they sorted them out in batches of 5 or so to a pile to test them. One set was left as-is, others were soaked in different oils for a set amount of time. They then put a socket with a torque meter on it to see how much torque it took to break loose the nuts. You'll never guess which one came out ahead by a pretty fair margin.
A 50/50 mix of ATF and acetone.
was surprised too, but the torque numbers didn't lie. It spanked all the known favorites we've used our entire careers. I gave it a shot and mixed up a batch myself as a skeptic and (now former) worshiper at the PB Blaster alter. You can put it in a cheap dollar store squirt bottle, or pony up a few bucks for one of those Sure Shot sprayers you pressurize with your air compressor. Best part about this stuff is it is dirt cheap compared to buying aerosol cans of penetrant.
Mix up a batch and try it. I used the no-name dex/merc ATF and painter's acetone from the local hardware store. I don't think the more expensive synthetics would be much different in results, but if a guy wanted to conduct a study like the one I read about to see if there was a difference, by all means go for it.
Thought this was too good of a tip to keep under my hat. Try it out and tell me what you think.
Ehk siis lühidalt ja eesti keeles, meil eestis PB Blasterit ja Kroili minuteada ei müüda, küll aga võid proovida 50:50 ATF ja atsetooni segu, väidetavalt "hammustab" paremini ![]()
Ise katsetan selle kindlasti järgi, kui mõni selline moment peaks tekkima, et vaja läheb.
https://www.autokaubad24.ee/et/tooted/o ... exronii-1l
http://ehituseabc.ee/ehituskeemia/varvi ... -rilak-1l/
h0lger
- Tsikkel: roheline
- Tänatud: 30 korda
Tundub huvitav, Piipz.
Kui WD40 feilib, siis saab ilmselt see möks võimaluse.
h0lger
- Tsikkel: roheline
- Tänatud: 30 korda
jaan mmc kirjutas:Võibolla tömbi otsaga automaatmeisliga võlli otstest meiseldades, hakkab pikapeale liikuma
Kuna ma olen seda juba kuvaldaga päris palju töödelnud, siis rattalaagrite vahetusega olen juba arvestanud. Loodan, et pesad jäävad siiski terveks.
- Tsikkel: Honda VFR800, 2008
- Tänanud: 492 korda
- Tänatud: 600 korda
panen oma kopikad ka suruõhumeisli peale.
jaan mmc
Kui laagritele peaks olema külgedelt ligipääs, võib ka separaatorid lõhkuda ja kuulid välja nokkida, saab äkki võlli koos laagrite sisesaaledega välja võtta
Keerme poole pane võlli otsaga tasa, meiseldamise ajaks kindlasti vähemalt 1 cm laiune mutter, see väldib võlli otsa "laiaks neetimist" ja vedelikuga leotamine on muidugi igati asjakohane.
Varjant oleks ka võlli otsi kuumutada, kuigi ma ei julge pead anda, et see võlli tugevusele halvasti ei mõju ![]()
h0lger
- Tsikkel: roheline
- Tänatud: 30 korda
Aitäh kaasamõtlejatele!
Võll on eemaldatud - pool purki WD40't, 24h leotamist ja kuvalda olid koodsõnad.
Mutter on lännu, ilmselt võll ka. Laagritest otseselt aru ei saa, aga igaks juhuks vahetan ära.
