Suzuki GSX600F karburaatorid
See Dynojet kit peaks hoopiski olema düüside komplekt, millega peaks võimsust juurde saama. Nägin seda ka ise, kuid see pole see asi, mida mul vaja.
Piipz, mul ongi masin Motoremis, aga mulle soveldamise varianti ei pakutud. Kas sa räägid muidu ujuki nõeltest ikka või mõtlesid neid http://www.dansmc.com/jet_needle1.jpg ? Motoremist öeldi, et ujuki nõelad on kulunud. Üks väike tekst ka asja kohta:
The fuel level is controlled by the fuel floats and the fuel float valve. The floats are hollow or made of something that will float on gasoline, such as cork. Part of the float presses against the float valve, sometimes called a needle and seat. Most times the part of the float that touches the float valve needle is bendable so you can adjust the level of the fuel in the floatbowel. All plastic floats are not adjustable. If this level is way too high, gas can leak out the carb overflow tube or into the engine. If fuel gets into the engine it will thin out the engine oil, ruining it's ability to lubricate. This will, sooner or later, blow up your engine ! If a full tank of gas in the evening turns into a half tank by morning, check your oil. If it's thin and smells like gas, change it and replace your float valve and/or check your fuel level. If the oil is OK, check under the overflow tube. If it's OK, then check where you are parking your bike 'cuse someone is walking away with your gas !
Vahetada seal peale ujukinõelte ilmselt midagi pole. Küsin igaks juhuks Motoremist soveldamise kohta.
Suzuki GSX 600 F
