Trolltunga Norra
kumar
Teema algataja - Postitusi: 633
- Tsikkel: Hayabusa Turbo 2012//288 RWHP
Trolltunga Norra
Terekest. Kas keegi on käinud sellises kohas nagu Norra Trolltunga. Sinna päris ligi ei pääse.siis oleks selline küsimus.et palju sinna maad on kõndida ja kui kaua läheb aega kõndimisega sinna ööbimis kohast.
Ette tänades.
Ette tänades.
- Tsikkel: XV1600
- Tänanud: 372 korda
- Tänatud: 248 korda
Re: Trolltunga Norra
Norrakas räägib:
Trolltunga is one of the most spectactular scenic cliffs in Norway. Trolltunga is situated about 1100 meters above sea level, hovering 700 metres above lake Ringedalsvatnet in Skjeggedal. The view is breathtaking. The hike goes through high mountains, takes 8-10 hours in total (to Trolltunga and return) and the ascent is about 900 meters.The hike is usually possible to do from mid June, depending on when the snow melts in the mountains. Normally one can hike to Trolltunga until mid September. Consider carefully whether you are in good enough shape and have the right equipment before setting out. Plan carefully and start early in the day. There is no mobilephone coverage along the route.
For more detailed tour descriptions
From Odda you can drive to Tyssedal on route 13. From Tyssedal follow signs to Skjeggedal. Parking in Skjeggedal after 7 km. Parking fee NOK 100 pr day in Skjeggedal. The hike starts at the beginning of the funicular Mågelibanen (not in operation) in Skjeggedal. Follow the path that starts on the right side of the funicular. The path is marked with painted red T’s in the terrain. There are some signs along the route.
If you want to stay overnight in the mountain area around the Trolltunga we recommend bringing your own tent.
All nature based activities are at your own risk. You will need sturdy hiking boots, bring extra clothing and be prepared for bad weather. Bring map and compass, food and drink. Respect the nature. Weather in the high mountains can change quickly - check the latest weather forecast before going to Trolltunga.
Trolltungal küll ei käinud kuid öömaja tasub Oda piirkonnas varakult valmis vaadata. Majutusasutusi on vähe ja lähedalasuv Summer Skii Centre hoiab motellid täis. Paljud kohad on pikalt ette broneeritud. Meie augusti alguses alustasime öömajaotsinguid kell 18:00 ja vabu kohtasid lihtsalt ei olnud.
Hr.Nõel
- Tsikkel: Päris mitu...
- Tänatud: 100 korda
Kas norrakas eesti või soome keeles ei räägi.
Huvitav, miks ta peaks ?
Saan aru, et kui siis vene keelt. Aga praegust majanduslikku olukorda/rutsi nõrkust arvestades ei rända vist venelane ka eriti.
Laur
- Tsikkel: VTX1800R
Norras saab inglise keelega hakkama enamus kohtades.
M.O.T.T
Kevadlilleke
- Tsikkel: FZR
Skjeggedalis sealsamas auto parkimise kõrval sai täitsa vabalt telkida. Üks võimalus, mida võib ka kaaluda, on saabuda Skjeggedali (pärast)lõunal ja enne pimedat mäkke ronida ning trassilt veidi kõrval telkida. Saab ka Trolltungal ära käia järgmisel hommikul enne turistide horde ning jõuab parklasse tagasi normaalselt enne pimedat. Üks miinus sellel mäestelkimisel on - see funikulööritrepp on suurema koormaga tappev nii üles- kui allasuunal, 400m kõrguste vahet järsu trepiga.
Noh? Päris kõva, mis? Onju?
Nojah, ainuke jama on selles, raisk, et, kuradi, kaua ei saa nii lasta - tõmbab... tõmbab aku tühjaks...
kumar
Terevist. Oleks selline küsimus.kes on kohal käinud(trolltunga). Et viimane sihtkoht.kuhu pääseb masinga Skjeggedal. Kas ja kuidas seal tsikkli varustusega lood on. Kas saab need kuhugile koha peale jätta hoiule või tsikkli juurde. Tsikkli juurde on vähe kahtlane jätta. Pärast mõni ajuhiiglane mõtleb tuuri asjad panna. Igasugune asjalik info on teretulnud.
Käisin kaks aastat tagasi seal tsikliga. Rahvas telgib ümber parkla, jätavad ka telgid päevaks sinna, kui mäkke lähevad. Ise jätsin tsikli koos varustusega ka sinna, tõmbasin ainult katte peale. Üldiselt on tegu Norraga, seega karta pole seal vaja, ja pole kohanud, et kuskil mägedes keegi midagi varastab. Kate on ka hea asi, varustus silma alt ära.
Tegelikult trepp ei ole selleks mõteldud, trepiga paralleelselt kulgeb ka oluliselt lihtsam matkaradaKevadlilleke kirjutas:Üks miinus sellel mäestelkimisel on - see funikulööritrepp on suurema koormaga tappev nii üles- kui allasuunal, 400m kõrguste vahet järsu trepiga.
