BO õpetus kroomile
BO õpetus kroomile
guys, after 10 seconds of amazing burnout experience, i decided that i am qualified as an expert in this field.
first of all, check for cops. they hate this stuff.
find ladies to do this in front of. they love it.
1) make sure your bike is nice and hot. doing this on a cold engine is not good. at all.
2) find some nice clean, level ground. make sure your front tire isn't in a puddle of anything, and this includes water. you need clean ground or bad things will happen. if you can't find clean pavement, find a curb.
3) put your high beams on. the smoke looks cool with lots of light going through it.
4) select 1st gear.
5) stand up, straddling the bike. keep your legs close to the bike to keep it in position.
6) grab the front brake HARD with all four fingers. you'll be using your thumb to control the throttle. no two-finger crap here.
7) start revving like an asshole. this gets everyone's attention, makes you look cool, and gives you extra poser points if you have a loud exhaust like mine.
use your weight to press down on the bars. you're trying to load the front tire.
9) rev to about a steady 5-6k
10) drop the clutch (yes, DROP it, don't slip it) while rolling on some extra throttle.
11) keep your eyes on the tach at all times. it'll shoot right towards the redline. modulate the throttle
12) enjoy the smoke. think about where you're going to order your next tire from.
13) pull the clutch in while closing the throttle.
DO NOT RELEASE THE FRONT BRAKE OR TAKE YOUR WEIGHT OFF THE BARS UNTIL THE REAR WHEEL HOOKS UP AGAIN.
have fun.
-Ryan
4) select 1st gear.
have fun.
-Ryan
